97 Volvo S90 power seat stuck
Old May 2, 2010 | 10:57 AM
badbob's Avatar
Default 97 Volvo S90 power seat stuck
Howdy ! I wanna know if anyone knows where I can buy a power seat drive cable (for back and forth) for a 97 Volvo S90 OR is there a way to fix the original. The problem is that only one side of the seat moves while the other side is stuck. My wife normally drives the car and the "stuck" seat position is fine for her but I need a lot more leg room. I'd sure appreciate any help. Thanks
Old May 2, 2010 | 11:03 AM
I have heated the metal sleeve many times and pushed the outer shielding into the sleeve more. That shortens the outer sleeve making the center part of the cable go back into the motor.
After heating and pushing it in push the switch to move it and drop the cable into the motor.
Old May 2, 2010 | 11:14 AM
badbob's Avatar
Thanks for the speedy reply ..I haven't tried to take the cable out yet.. is it difficult to remove/replace? Any special tools needed?
Old May 2, 2010 | 11:19 AM
I do it in the car using a mini torch and long needle nose pliers.
Old May 2, 2010 | 11:29 AM
badbob's Avatar
Thanks very much.. now all I need is your years of experience and a lot of luck!
Old May 2, 2010 | 11:32 AM
Work slowly and be careful and you should be fine.
badbob
Jun 12, 2014 03:25 AM
rwswwhite
Nov 23, 2010 08:04 AM
roy321
Sep 23, 2010 07:57 AM
NCS60
Apr 20, 2009 01:57 PM
pleonard
Nov 17, 2007 09:30 AM
