Brake Failure Stop Safely then car dies
Old Nov 30, 2021 | 08:32 AM
  #21
here's a thought - take a hair dryer and blow hot air on the ABS controller and CEM to simulate a warm day. If your codes start popping up you may have a thermal expansion issue creating a short or open. You can also do the opposite - buy some electronics cold spray or compressed air in a can (at an electronics store like Best Buy). when you get your codes, spray the ABS controller to cool it off to see if your codes resolve. Do the same for the CEM.
Old Mar 7, 2022 | 08:47 PM
  #22
pooky1279's Avatar
Originally Posted by zerochills
Now have all the original faults/error messages as I originally did...
Check Engine
ABS
DSTC
Park Brake (blinking)
Brake
Red Triangle w/ exclamation mark
DSTC Service Required
Coolant System Required
Park Brake Service Required
Park Assist System Service Required
Power Steering Service Required
Should I now be leaning toward the CEM???
If so, why after the car sits for a few days, it starts up fine with no codes then after about 10min of running, all come back?
Or could this be all tied to the high voltage output???
Now my 2012 volvo S80 does the same thing except my radio won't come on and it doesnt recognize it's in park. Did u figure a solution cuz my car has been down 3 months. And I need my car back running!?
Old Mar 7, 2022 | 09:29 PM
  #23
Any codes stored in the car/CEM?
Any evidence of water intrusion on the CEM?
Have you considered taking your car to a Volvo Specialist?
Old Apr 18, 2022 | 03:29 PM
  #24
qarltoran55's Avatar
Any update on this issue?
Old May 20, 2022 | 08:39 AM
  #25
Luking's Avatar
Hi, did you fix the problem? Thank you
Received CEM back from cloning service. Installed and fired car up with fingers crossed... NO LUCK
Still have no power steering and DTC's:
*Loss of Comm w/ TCM
*Internal Control Module Software Incompatibility
*Control Module Comm Bus "A" Off
*High Speed CAN Comm Bus
Old Jun 30, 2022 | 04:54 AM
  #26
matke's Avatar
Hi,
Did anyone solve the problem? I have the same issue with Volvo V40 D3 2013.
All the best
Old Oct 9, 2022 | 09:47 AM
  #27
Bwatson40's Avatar
Default Brake Failure stop safely 2013 c70
I have had my car for 8 years and never had issues. I took the dealer and had front brakes replaced and 3 weeks later I started getting this error. VOLVO towed it to the nearest dealer and they kept it a week and saw no issues. I told them about brakes being replaced but they said there were no issues and they could find no codes. It worked for them every time. We picked the car up on Thursday around noon. It cranked perfectly. We drove the car several times on Friday no issues. We drove th car Saturday about 100 miles out of town and got there. No issues. The car sat for a few hours and we headed back to our town got 15 miles outside of town and the car stopped for the same issues. Started with brake failure messages and then it started flashing 4 other codes.
We would not cut the car off so the engine stayed on but nothing else worked. When the tow truck driver arrived it would not even go into neutral. We had to tow the car 79 miles back to the dealership and we had to pay 300 dollars because volvo only covered 25 miles.
This is dangerous and it makes no sense w
hy Volvo doesn't see the issue. It has to be a computer software issue
Old Apr 19, 2024 | 02:40 PM
  #28
jowilam's Avatar
Hi! Any update for this issue?
Thanks
Old Nov 30, 2024 | 01:05 PM
  #29
Blaisetyme's Avatar
Default Replacing my battery solved this isssue
Hi all, I recently had this happen to my 2012 Volvo C30. Every single thing described in this discussion occurred. Finally, the tow truck arrived to tow it to my mechanic. The guy walked up, turned, and said, "I think it's just your battery."
He replaced the battery with a new one, and it solved the issue.
He says he's seen it on other Volvos, when the battery is getting old, low, weak, or dead, this can happen.
Maybe try replacing your batteries.
zerochills
Dec 29, 2024 06:55 AM
Shaun Swegman Sr
2001-2013 model year V70
Jun 1, 2017 07:55 PM
TomT
2001-2013 model year XC70
Dec 19, 2016 04:54 PM
kase6000
Apr 21, 2015 04:36 PM
Quick Brick
Jul 26, 2009 04:06 AM
