C70 vibration problem after fitting newe mount
Old Apr 25, 2009 | 04:11 PM
mick1232's Avatar
Default C70 vibration problem after fitting newe mount
I need some advise on this one,Ive just replaced my top torque mount on c70 T5 Coupe when i start the engine and rev it the car is shaking its **** off ,vibrating through front end and steering wheel.This never accoured until replacement BUT!! when i take out the bolt that goes through the anchor and mount it goes away ?????? Is there something too tight about this part and the bush cannot absorb the vibration Its an OEM part excatly same as the one i took off bought from volvo
Attached Thumbnails C70 vibration problem after fitting newe mount-top-torque-mount.jpg
Old Apr 25, 2009 | 07:05 PM
mkc70's Avatar
It is connected at the fire wall directly to the cabin so I could see it making more vibration. This would not be the case though if one or more other mounts were bad as well. Have the same square style mount on my car with no issues.
Old Apr 25, 2009 | 09:21 PM
Double check the top black cover and make sure when you put it back on you did not pinch a wire to one of the coils.
Also I hate the mounts in the picture above. IMO they are like having bad mounts.
Old Apr 26, 2009 | 04:59 AM
mick1232's Avatar
Tech why do ya want me to check to see if ive nipped a coil wire m8 ?.It's not missing engine is running fine .I'm sure these mountings volvo r giving me are wrong for my car i used to have a round 1 on and the bracket anchor was different also. The bracket that goes to the back on chassis seems to be the wrong type for the mounting pics below
Attached Thumbnails C70 vibration problem after fitting newe mount-c70-2001-anchor-bracket-1.jpg   C70 vibration problem after fitting newe mount-c70-2001-anchor-bracket-2.jpg   C70 vibration problem after fitting newe mount-volvo-200405-v70xc70.jpg
Old Apr 26, 2009 | 06:43 AM
My bad somehow I did not see the part about it going away when you remove the bolt.
The mount they gave you is an updated one. The bracket going to the firewall is the correct one. The 3 picture you have posted is the setup for the newer cars where the mount bracket is part of a strut brace setup.
Like I also said above I have the square mount setup because they have way to much play brand new.
tuner4life
Apr 27, 2012 06:41 PM
blackbrick
May 11, 2011 12:18 PM
brownS70
Dec 30, 2009 10:15 PM
ocean238
Apr 17, 2008 06:20 PM
phonostudio
May 2, 2005 08:59 PM
