Changed timing belt won't start. 2.5T
Old Jun 12, 2017 | 03:55 PM
Michelle ForReal's Avatar
Default Changed timing belt won't start. 2.5T
I have a 2007 Volvo S60 2.5 Turbo the timing belt was changed water pump changed brand new battery brand new starter relay when you put key in a car and you turn it on it's all lights come on but it will not try to turn over Like The Engine is Dead Makes No Sounds so I put it on the computer and I got the code PO727 engine speed input circuit no signal... HELPP!!
Old Jun 13, 2017 | 05:44 PM
was the car running after the timing belt was replaced or did all this work done at once? I wonder if your replacing the battery set off the immobilizer. Have you tried locking and unlocking the doors with the key fob 5 times to see if it resets?
Ape0r
Feb 23, 2021 06:30 AM
blue96
Aug 10, 2013 11:44 AM
MNS60
Jan 6, 2010 09:10 PM
luvmyXC90
Apr 12, 2008 09:04 AM
patrickpar
Oct 26, 2006 11:17 AM
