control arm bushings..have nut and bolt?
Old Nov 26, 2009 | 05:16 PM
chef's Avatar
Default control arm bushings..have nut and bolt?
hi guys i recently had the control arm table bushing changed (the front and rear position ones)... i wanted to know..on each side of the bushing is there a nut and a bolt that holds it in place? or a big screw or nut that holts the bushing in place? thanks
fabs
Old Nov 27, 2009 | 06:38 AM
The bushings are pressed into the control arms then screwed to the subframe.
Old Nov 27, 2009 | 08:12 AM
chef's Avatar
Thanks Tech...just wanted to make sure... i'be been having some issues lately. Since the time i had a new control arm installed and the bushings changed, and it was at that time i installed the winter tires on steelies, i have a slight vibration in the steering wheel, usually once i hit 80km and up...the vibration doesn't get more violent as the speed goes up, but it's constant and i can feel it a bit more when i take my foot off the accelerator.
thanks
fabs
Old Nov 27, 2009 | 08:25 AM
Maybe have the front tires rebalanced.
Old Nov 27, 2009 | 08:50 AM
chef's Avatar
Hey Tech, actually i brought it back to my garage and the rebalanced all of them and retightend the lug nuts to 120 psi! and it still does this! can the lug nuts be too tight? that's what the guy at volvo recommended..
thanks
fabs
oh ya, i was thinking of doing my tranny fluid flush...the garage i go to uses BG synthetic oil...is this okay for my car? i know it needs mobil-1 3309 oil...
thanks
fabs
Old Nov 27, 2009 | 08:57 AM
Maybe one of the rims bent?
I would try to get the 3309 and have them use that.
jmallie
May 28, 2010 05:03 PM
nicolaselias
Mar 30, 2010 09:54 PM
Platinum52
Jul 17, 2009 07:33 PM
sy381
Jul 2, 2008 07:33 AM
nandrolone
Dec 28, 2006 11:14 AM
