Dead 2001 S80 T6
Old Aug 4, 2016 | 02:21 PM
VolvoX15's Avatar
Default Dead 2001 S80 T6
Engine will start but idle cycles up and down with no motion of the pedal. When held to the floor it will go about 1200 rpm. It has no power. If put in gear it will stall. It is very hard to move even on the level. I have replaced the mass air flow component. Anyone with some magic would be greatly appreciated.
Old Aug 4, 2016 | 02:42 PM
Smith Volvo's Avatar
Banned
ETM's are common on this model - should have some DTC's stored
Old Aug 4, 2016 | 03:44 PM
volvos80319's Avatar
definitely etm issue... clean it up... watch a you tube video.... and be careful with the plug.... Mine did that when it had moisture in the connection
Old Aug 4, 2016 | 07:32 PM
VolvoX15's Avatar
The only code I have had was for a intake air leak but it ran fine. Thanks to all for the direction. I will update when possible.
Old Aug 5, 2016 | 01:17 PM
donf's Avatar
Had an similar problem with an S70. Had worked on the car about a week before and it was driving well. All of a sudden it started doing the same thing. Nightmare getting home, 10 blocks. Found a loose hose clamp on a turbo hose - tightened it and all was good, except for clearing the damn code.
Old Aug 12, 2016 | 11:47 PM
many Autozones will scan codes for free and clear if you ask. If you have your VIN handy and they will map codes to probable replacement part #s too (buying them is always optional )
rcglextacy
2001-2013 model year V70
Sep 19, 2012 10:07 PM
laronsue2
Nov 30, 2010 10:55 AM
BigAdam
Aug 24, 2008 03:18 AM
whatda?
Aug 9, 2008 07:35 AM
jjdche
Dec 12, 2005 01:24 PM
