Defroster Failure
Old Jan 16, 2008 | 08:44 PM
850 buddy's Avatar
Default Defroster Failure
Front window defroster on 1999 XC70 is barely working. Air blows hot through defrost vents and there is no evidence of heater core leak. AC charge tests normal and window is very clean on the inside. The defroster just seems ineffective. Any suggestions or relevant experience.
Thanks,
850 buddy
Old Jan 18, 2008 | 09:16 AM
JPN's Avatar
JPN
Default RE: Defroster Failure
Make sure that the ventilation mode isn't set at "REC"-recirculation mode; turn the REC mode off or set it at fresh outside air. Refer to the owner's manual as I am not privy to XC70.
If it's at REC, the air will keep recirculating within the cabin and the moisture is there to stay no matter what. If, however, it is not at REC, then the cause of fog up is beyond my knowledge.
JPN
Old Jan 18, 2008 | 07:56 PM
Eric J's Avatar
Welcome to the forums 850 buddy.
This^ man can fix jets. Nothing is beyond his knowledge,so I'm sure this is good info.
charlesbattaglia
Jan 19, 2006 11:09 PM
miker
Dec 22, 2005 02:39 PM
cool_kyle_3000
Dec 21, 2005 04:51 AM
copurnikus
Oct 18, 2005 04:54 PM
EmailBenn
Oct 9, 2005 09:05 AM
