Disconnecting fuel line from filter, why does volvo use fuel connectors from hell ? (
Old Aug 1, 2023 | 02:44 AM
shodanx's Avatar
Default Disconnecting fuel line from filter, why does volvo use fuel connectors from hell ? (
title Disconnecting fuel line from filter, why does volvo use fuel connectors from hell ? (And how to disconnect them ?)
Hi,
I have a XC70 03 with leaking rusted fuel filter
Got a new filter, tried to replace it but it didn't work as I'd hoped.
On the fuel line connectors, there are gray tabs that you're presumably supposed to press to release the hose.
I pressed them, the hose turns but it doesn't release. Got in a better position, pushed as hard as I could with my fingers, I cut myself a little, push-pull-twist-yank-push-pull and so on, it just won't let go
I squirted a bunch of penetrant lubrication fluid into the hose connectors
https://imgur.com/ql675vX
https://imgur.com/LhS03c4
I tried squeezing it with the vice grip, but that doesn't squeeze the tabs, it just holds on to the connector's body
https://imgur.com/SJYJHh9
I tried the smaller vice grip but same thing
https://imgur.com/OWFtKg9
I tried wrapping zip ties around it and squeezing the heads of the zip ties onto the gray tabs
https://imgur.com/8Ssdo4S
But the awkward position, trying to juggle the zip ties, the vice grips and everything was just too much !
So I had the idea to put tape around the connector
https://imgur.com/Uo6iU39
And then stick the cut heads of the zip ties in place
https://imgur.com/Iin6cW7
Now I've got them good on there !
https://imgur.com/GX4Omwp
push-pull-twist-yank-push-pull again, but it won't budge, it does turn just fine but it won't come out ! Yes, I tried pushing hard !
The tabs are pushed in permanently now, I wonder if that's going to be an ever bigger problem ?
https://imgur.com/lN0nkiw
I went on youtube and the forums, looking for the trick maybe ?
youtube and forum results here
A video showing you should be able to take it off with just your hands
this video is from an XC90 but it's the same setup
Another video showing just how dam easy it is supposed to be
fcpeuro, showing again that it's super easy
these guys are using some tool
this person has the same problem, pushed on the buttons using open end wrenches
https://volvoforums.com/forum/volvo-...t-stuck-60568/
this person used jumper cable clamps
https://volvoforums.com/forum/volvo-...el-pump-50495/
this person gave up and brought it to the dealer
https://volvoforums.com/forum/volvo-...onnects-70542/
this person didn't resolve their stuck fuel filter, suggested using a special tool or going to dealer
https://www.matthewsvolvosite.com/fo...ter+disconnect
this person did the fix, and then it blew out the lines under pressure, suggest
https://www.matthewsvolvosite.com/fo...c.php?p=599775
This post also mention they are hard lines covered with rubber so you can't just cut them and clamps
https://www.matthewsvolvosite.com/fo...c.php?p=448365
This person cut the line, discovered they are hardlines, they have not been heard from since and are presumed dead
https://www.swedespeed.com/threads/2...nnects.656305/
This person says "couldnt be easier"
https://www.swedespeed.com/threads/f...easier.354018/
This person's mechanic broke the connectors and replaced with generic screw hose clamps, are worried about leaking gas on the exhaust
They reported putting 1000 miles on the car, they have not been heard from since and are presumed dead
https://www.swedespeed.com/threads/f...-v70xc.218735/
This person broken the fuel filter connector, paid 990$ plus towing to have it fixed by replacing the entire line
https://www.swedespeed.com/threads/f...1/#post-894536
This person says to squeeze, push then pull
https://www.volvo-forums.com/threads...390/#post-3281
This person also tried everything in 2009, they have not been heard from since and are presumed dead
https://www.volvo-forums.com/threads...8/#post-112439
I see on ebay, there are special pliers that might do it ?
https://imgur.com/Hac0Wbz
https://imgur.com/5jqb3VK
my friend lended me his dad's hose disconnect tool kit as well as a pep talk
https://imgur.com/4GHgV8y
I tried the 1/4" tool
https://imgur.com/mZ7hiVt
I tried the 5/16" tool
https://imgur.com/32ReE62
I tried the filter inlet side, that's the leaking side, it broke off immediately
https://imgur.com/yzwk3Vq
https://imgur.com/cclaFBg
It's not budging, mosquittos are eating me alive and it's 3AM so I'll try again tomorrow
Another day, what we're looking at here
https://imgur.com/CKPaYbr
https://imgur.com/6ZeBbQe
1/4" tool again, it's in the "out" position
https://imgur.com/iKrRZOH
1/4" tool, in the "in" position
https://imgur.com/Tj71yZX
Trying to have a look inside the connector
https://imgur.com/PS8E6fS
https://imgur.com/6PhHowN
Trying the 5/16" tool again
out position
https://imgur.com/Gg75DNx
in position
https://imgur.com/6Azss9r
Trying another tool that fits
https://imgur.com/HkARy0i
I can hear clicking sounds, but it's not moving
https://imgur.com/gcpDU89
I tried with the zip tie heads again
https://imgur.com/DBIk4hv
https://imgur.com/HN0kFkd
It's well squished
https://imgur.com/gDVoTtr
And I've got another tool to help me pry the connector from the filter
https://imgur.com/9IXFJMf
Well, I'm stuck, I also tried heating the line with a hair dryer, but no effect
I ordered the two fuel line disconnect tools off ebay, I hope they will arrive before the end of next week !
Is there any way to buy replacement hose end connectors, so I could just cut off the lines and push in new connectors ?
I really really really don't want to change the lines, especially not the line that goes to the fuel pump !
I've seen that you have to cut a hole in the floor or drop the subframe to get at the fuel pump so .
Old Aug 2, 2023 | 09:35 AM
firebirdparts's Avatar
They do that for ease of assembly.
With the tool, you typically have success. They generally work. You typically have to push the connectors toward the filter a bit to unload the pressure on the locks. Pushing away does not help. All that stuff is repairable, but boy, do I hate repairing it. It is torture. So try not to break anything.
From the looks of those vice grips, you may be defeating yourself by pulling. Everything there needs to push in to unlock.
Joel_S
Jul 23, 2014 08:48 AM
TheSteelKnight
Aug 15, 2007 12:50 PM
S70driver
Volvo C30
Jul 30, 2007 03:36 PM
JPN
Feb 2, 2007 02:04 AM
S60D5
Nov 27, 2006 11:21 AM
