Engine over revving.
Old Jul 25, 2008 | 12:01 PM
kpmaca's Avatar
Default Engine over revving.
Hi all,
My 1999 V40 engine managment light has come on and the enginehas started to over rev when i'm driving and alsoat idle, going up to near 4000 revs.
Took it to my local garage who said that the crankshaft sensor was faulty, they replaced the sensor but it was still over revving. They then informed me that the old sensor was damaged by something in the housing and would they would have to remove the gearbox to have a look to see what could have caused the damage, also the cam belt is in need ofreplacing.
Could these problems be the reason the engine is over revving or are they justclueless..........
Anything else I should be looking at..
Thanks
kpmaca.
Old Jul 26, 2008 | 09:11 AM
Default RE: Engine over revving.
A Bad coolant temp sensor is a common cause of your problems.
Old Jul 26, 2008 | 12:22 PM
kpmaca's Avatar
Thanks for the Info.
Do you know of anything that could have caused the damage to the crank shaft sensor.
regards
kpmaca
Old Jul 26, 2008 | 12:24 PM
Have you had any gearbox work done or rear main seal replaced?
Old Jul 26, 2008 | 01:11 PM
kpmaca's Avatar
No.
The garage want to remove the gearbox to do an inspection, which is not going to be cheap....
So any advice would be much appreciated.
regards
kpmaca
Old Jul 26, 2008 | 02:09 PM
Usually if the crank sensor is bad or damaged it will start hard not rev high. I would replace the coolant temp sensor and thermostat first. Is there any codes on the system?
Old Jul 26, 2008 | 03:08 PM
kpmaca's Avatar
Not sure what you mean by codes......They said there were a lot of faults that came up, but the crankshaft sensor was definately down and it would be the cheapest to start with.
will tell them to replace the coolant temp sensor and thermostat next.
Do you think it would still be a good idea to remove the gearbox for an inspection to see what caused the damage to the crank shft sensor, as the end of the sensor wasbroke off and the copper wire coil hanging out.
regards
kpmaca.
Old Jul 26, 2008 | 04:19 PM
Unless someone broke the bracket holding it I cannot think of anyway it could be damaged. Or unless something somehow got dropped in there.
Old Jul 28, 2008 | 08:18 AM
kpmaca's Avatar
Just had the timing belt changed and the cars running great, all the faults have cleared.
Thanks for your help and advice.
Nice to know there are people here ready to help.
kpmaca
kylebooth
Nov 14, 2009 05:41 PM
maddox
Jun 19, 2009 07:06 PM
Bruce Wayne
Apr 3, 2009 11:10 PM
maddog
Jun 19, 2008 07:21 AM
trhillar
Oct 18, 2005 09:32 PM
