gear lube vs engine oil.
Old Feb 11, 2015 | 11:02 AM
bobby ray's Avatar
Default gear lube vs engine oil.
i recently purchased a 1965 p-1800 and i am confused about transmission/over drive lubricants. service manual says that sae 80 gear lube is for tranny. it says sae 30 motor oil may be used also? it says the od uses motor oil sae 30? my question is: does the od get its' oil from the tranny or are the two (tranny/od) separate things that are filled with different lubricants?
rspi
Mar 18, 2013 02:12 PM
carlheat
Oct 25, 2010 10:36 AM
dror_idn
Oct 28, 2009 04:39 PM
klaus
Aug 2, 2009 09:08 AM
