How to check trans fluid on 2012 S60 T6
Old Dec 12, 2020 | 10:22 PM
teesix's Avatar
Default How to check trans fluid on 2012 S60 T6
Sorry if this is a stupid question... any help would be greatly appreciated.
Old Dec 13, 2020 | 05:08 PM
what transmission do you have? If its the six speed Aisin, there's no dipstick and the fill level is set by the drain port, If you go under the car the transmission fluid drain has a double bolt - the inner opens a port to the overflow tube which sets the level and the outer bolt removes the overflow tube which allows the fluid to be drained (VW's DSG transmissions use a similar design to set the level). Note that the fluid level is set when the fluid temp is 55C - which typically requires a VIDE DICE to read the transmission's temp sensor.
Old Dec 25, 2020 | 08:22 PM
teesix's Avatar
Got it! Yep that's the transmission. I'll go ahead and let a shop do it, since that seems a little much for me to do on my own. Thank you for your help.
Old Dec 26, 2020 | 09:38 AM
Stewart-18's Avatar
simp
Apr 29, 2024 09:52 PM
teesix
Dec 12, 2020 10:11 PM
michineme
Nov 1, 2020 12:09 AM
brianw
Dec 29, 2019 04:39 PM
Simon Labrecque
Oct 17, 2019 01:49 PM
