i have a problem
Old Jan 8, 2020 | 09:12 PM
bikerralph56's Avatar
Default i have a problem
i have a 2001 v70 2.4t i was coming home and it lost power it did in my yeard and wont start it had acod that camtimeing was out the vvt was bad i replace it and it steel wont start i have chack avery thing it steel wont start can somone help
Old Jan 9, 2020 | 08:31 AM
VVT timing should not cause a no start. Did you check to make sure your timing belt is intact - what did you do to when you replaced the VVT? ie just the sensor, the solenoid, the whole VVT hub? Have you checked for spark and fuel, compression?
Old VW Dude
Apr 29, 2019 07:37 PM
zeb6234
Dec 13, 2014 03:22 PM
DLD24
Feb 1, 2014 09:54 PM
Louise Roy
May 2, 2012 04:01 AM
