injector open?
Old Sep 28, 2022 | 12:40 PM
VOLVO971's Avatar
Default injector open?
Hi all, I have a problem with my (240 swap 740 B230et motronic).
The car has been running with the current configuration for years, without failures.
These days, I stopped and when restarting, the car did not want to, it smelled of gasoline. I waited a few days and the car started, cleaned filter, injectors and new spark plugs. The car is running more smoothly, but still the same, if I stop and start it again, it is as if it drowns. Then, pushing it, it starts and it smells of gasoline and it seems to be drowned. I have thought that some injector is perforated and is leaking fuel...
Thank you very much in advance.
Old Sep 28, 2022 | 04:09 PM
did you pull the plugs to see which is fouled?
Old Sep 28, 2022 | 11:10 PM
donf's Avatar
He said he replaced the plugs. Would it not be easier, and quicker, to put a fuel pressure gauge on it and see if it is actually pouring fuel out? He also said he cleaned the injectors but I guess you could clean a failed injector and not no it.
Last year, I had a (non-Volvo) car with a terrible injector, but the plug to that cylinder looked good.
Old Sep 29, 2022 | 01:36 AM
VOLVO971's Avatar
i have a fuel pressure regulator, and the car worked perffect at 4 bar (i got a big pump onñ¡ly one)...
Im thinking about the fuel pump relay... but i have a BIG BIG questio, anf i was for a two days , and talked with ipd andnothing about this question:
Which relay fits on B230ET motronic? OEM number. For me, impossible to find it. I know exist from UK, australia, america... europe, my model is europe zone.
I know before the relay was green, but now is white... i only have this from auto parts (autodoc) . Relé, bomba de combustible
HERTH+BUSS ELPARTS - 75614234
thanks a lot.
DrHippo
Aug 31, 2018 08:15 PM
Hobo
Mar 9, 2017 05:28 PM
beleive
Nov 8, 2016 04:28 PM
Aredd95
Aug 20, 2015 11:08 AM
jefhon
Sep 20, 2012 09:43 AM
