Knock sensor question
Old Dec 18, 2016 | 10:15 AM
xerxes66's Avatar
Default Knock sensor question
Can anyone tell me what the symptoms are for a failed knock sensor? My 2000 C70 will start & idle well but refuses to accelerate once it's warm. If not the sensor, any ideas? Could the alternator be at fault?
I just bought it and can't drive it!
Thank you!
Old Dec 18, 2016 | 11:17 AM
Have you tested or replaced the engine coolant temp sensor? there are also temp sensors for the intake air preheat and a blend door that can get stuck where it pushes only the preheated air but that's less likely. Do you have a check engine light or have tried scanning for codes? I would not suspect knock sensors or the alternator. My check list would be engine temp sensor, air leaks on the intake (ie hoses/boots), fuel pressure (pump, pressure sensor/regulator), MAF or throttlebody...
rdklxprs
Jul 21, 2015 09:46 AM
andrewwhite149
Apr 22, 2012 01:33 PM
Peanut2
Sep 11, 2010 05:25 PM
ruggles
Mar 3, 2010 04:19 PM
lizard
Sep 1, 2005 08:48 PM
