Loud noises when i break
Old Oct 11, 2021 | 01:02 PM
eastonkoller@gmail.com's Avatar
Default Loud noises when i break
when i press the break i get a very loud low pitch rubbing noise and huge vibrations. it also happens when i drive the car just not as loud. it’s very bad and i don’t know what is wrong with it, can someone help?
Old Oct 11, 2021 | 02:31 PM
What year and model?
Old Oct 12, 2021 | 07:43 PM
sounds like you have completely worn out a brake pad and you have metal on metal (ie the rivets in the brake pad are digging into the rotor). A simple inspection can be done by removing the wheels to check the rotors for scoring. A side note, when this happens, quite often its due to a frozen caliper so you may need to replace that part as well the the pads and rotors (always do these in pairs ie both fronts or both rears).
Karmann
Mar 24, 2011 06:26 PM
Bemfica1
Jun 7, 2010 05:30 AM
rspi
Jan 20, 2010 11:32 PM
Sweet T5R
Jun 4, 2007 06:28 PM
