Make Key Fob Great Again
Old May 5, 2019 | 06:59 PM
LooseMoose's Avatar
Default Make Key Fob Great Again
Classic volvo owner, but recently upgraded to a modern model with those keyless fobs.
The fob automatically unlocks the car within a certain proximity. I don’t like this.
Any users aware of how to disable or override the auto-unlocking functionality of the fob?
I only want the doors to unlock when deliberately pressing the unlock button.
Old May 5, 2019 | 10:13 PM
ES6T's Avatar
It shouldn't actually unlock the car, it allows the car to be unlocked when you put your hand around the handle.
Not sure what year or model you have, but some have a setting to this happen to all doors or just driver's door I believe.
Old May 6, 2019 | 04:45 AM
LooseMoose's Avatar
Exactly. If the key is near, the car unlocks if anyone puts their hand in the door handle. I don’t think that’s safe.
If I have my inside the house, but just close enough proximity to the car in the driveway, anyone could slide their hand through the door handle to unlock. I have no idea volvo thought this was a great default setting.
is there a way to disable?
Old May 6, 2019 | 07:16 AM
ES6T's Avatar
Have you tested that it works with the key in your house? It doesn't even work with the keys on ny toolbox right in front of the car.
Old May 6, 2019 | 07:18 AM
LooseMoose's Avatar
Yes. Honestly, the main thing I like to do is hide the key in the bumper while outdoing watersports. Sounds like I simply can't do that anymore?
Old May 6, 2019 | 11:04 AM
ES6T's Avatar
No,I wouldn't do that unless you disable it. I still don't know the year or model so I can't tell you how.
Old May 6, 2019 | 11:07 AM
LooseMoose's Avatar
2018 v60 cc
Old May 6, 2019 | 11:30 AM
ES6T's Avatar
I find it hard to believe the keyless function works with the remote in your house. The working distance is supposed to be about 5 feet.
Removing fuse 12 in the fuse box under the dash on the passenger side (left fuse box) should disable it. See your owner's manual, pages 363 and 364.
Old May 6, 2019 | 11:57 AM
LooseMoose's Avatar
Hmm.. Good tactic. I think it's fuse 6. I'll try it out and report back. Appreciate your thoughts!
Old May 6, 2019 | 12:55 PM
ES6T's Avatar
Fuse 6 should work too. Fuse 6 is for the handles and 12 is the module the system uses.
Old May 7, 2019 | 06:46 AM
LooseMoose's Avatar
Tried removing fuses to no avail! I'm going to send Volvo an inquiry directly.
Old May 10, 2019 | 08:48 AM
ES6T's Avatar
Just tried removing fuse 6 on one, worked fine.
Old May 18, 2019 | 05:53 PM
blindkarma's Avatar
How about disconnecting the keyless antenna. There is actually more than one. If you look it up, you can find the locations.
volvo/s80/2005
Aug 3, 2019 10:20 AM
excentric
Jul 1, 2018 09:11 AM
hu5ker555
Nov 21, 2017 01:04 PM
850R_RBOAS
Jun 13, 2017 12:59 PM
planemaniac89
Mar 3, 2013 01:04 PM
