mystery cooling leak
Old Nov 10, 2018 | 11:26 AM
DanaT's Avatar
Default mystery cooling leak
2004 s60 AWD. Have to fill the cooling reservoir every week. System maintains pressure. No apparent leaks. Mechanic replaced thermostat housing and thermostat. No one seems to know where its leaking. No water or moisture inside the cabin. No white exhaust. I do need to replace the low level sender unit as it intermittently reports low coolant levels.
Any suggestions?
Old Nov 11, 2018 | 02:58 PM
did the mechanic do a pressure test? Look carefully around the upper and lower radiator hoses and side seams of the radiator for any discoloration. I had something similar on my son's S40 and it turned out to be the upper radiator hose - but I really had to look to see the stains.
Old Nov 27, 2018 | 11:51 AM
DanaT's Avatar
Yes, he did a pressure check. And when I open the reservoir there is plenty of pressure after sitting overnight. I need to get underneath for a better look.
lrivera1342
Jul 11, 2019 11:57 PM
Zenoxen
Sep 24, 2015 08:54 AM
tshort01
Jul 2, 2008 10:09 AM
jfunez
Aug 29, 2006 01:15 AM
heyma
Jul 19, 2006 12:18 AM
