Need a little more speed...any suggestions?
Old Nov 29, 2007 | 03:59 PM
TheChrncFairy420's Avatar
Default Need a little more speed...any suggestions?
Hey I have an '88 740 which i love for some reason, but i would like to make it just a little peppier. I don't know anythng at all about volvos so if anyone has any suggestions...
Old Nov 29, 2007 | 04:09 PM
S70driver's Avatar
Default RE: Need a little more speed...any suggestions?
Welcome to the forum.
Can you give us more info on your car. Is it the turbo model? If it was I am sure you would have said so.
Anyways, if your non turboed don't bother. Sell it and buy a turbo model. You wont get much power from a N/A (non turboed) model.
Old Nov 29, 2007 | 04:52 PM
S70_Driver's Avatar
Standard low tech hot rodding, which can be accomplished by any competent garage without pulling the engine, involves mostly increased breathing for performance at higher rpms - stuff like swapping camshafts for more aggressive profiles, lower restriction intake and exhaust systems, more aggressive fuel input. As with most things, it's a tradeoff though,and you can expect fuel economy and low rpm response to suffer.
Even these relatively 'minor' modifications can be quite expensive if you get them all done, so I would agree with the previous poster that the most cost effective thing, especiallyon an older used car is to buy one already setup the way you want from the factory. It'll be cheaper and will likely make better tradeoffs and be more reliable than any homebrew hotrodding.
Old Nov 29, 2007 | 06:11 PM
JPN's Avatar
JPN
This should give you "a little more speed"
.....just kidding[8D].
JPN
[IMG]local://upfiles/6892/6FA430E47992422095828F3196B56BA7.jpg[/IMG]
Old Nov 30, 2007 | 05:47 PM
Eric J's Avatar
Drop in a 454. (Well, JPN said to put in a jet engine!)
Old Nov 30, 2007 | 09:21 PM
jks2's Avatar
Only check your speed while you are going down a steep hill with a hurricane as a tailwind.
Old Nov 30, 2007 | 10:34 PM
Eric J's Avatar
Drop down to the 740 forum for more ideas or to Engine & Internal If you want to spend some money. Really, though, It's an older,conservative model........Just feel good, putting down the streets of Newport. People there will figure you are a yankee millioniare.
sdc2000
Jun 29, 2009 04:52 AM
luvmyXC90
Mar 23, 2008 11:51 PM
t5fun
Nov 8, 2006 09:23 PM
oldvolvobrik
Nov 2, 2006 06:21 AM
