New replacement Light not working
Old Jan 5, 2017 | 08:58 AM
Johnzielke100's Avatar
Default New replacement Light not working
2004 S60. Replaced bulb on passenger side and low beams still didn't work. Step 2 replaced fuse for passinger light and no success there. Help
Old Jan 5, 2017 | 12:09 PM
Not sure about your model year but in my 2000 S40, the low beams go through a relay inside the CEM. Before you start in on assuming its the CEM, best to do some basic connectivity tests to see if you have voltage at the connector, at the fuse, at the CEM pin. Could be as simple as a connector problem or a ground wire. Also, I assume you went with a new replacement bulb? Wiring diagrams can be found at volvowiringdiagrams.com
richardgrant
Apr 28, 2015 08:22 PM
rspi
May 15, 2014 07:36 AM
kerry
Oct 24, 2012 08:58 PM
BigAdam
Oct 21, 2008 10:01 AM
