No sp
Are you suspecting the crank sensor because you scanned for OBD2 diagnostic codes? sometimes you can get codes set due to things other than a fault in the sensor ie a battery/voltage issue, faulty ground wire or wiring connection and so on. This is what the a professional diagnosis that follows a factory recommended triage will review.
