Crank Position (rpm) Sensor pin outs
Old Nov 16, 2019 | 11:13 AM
Jojog's Avatar
Default Crank Position (rpm) Sensor pin outs
Have the wiring diagramming coming from the ECU and it shows:
  1. Red - guessing constant
  2. Blue - signal
  3. Black - ground
Also assuming it is 5V coming from the ECU to pin 1 (search found 12V on a pin and 5V on other pin and ground but cannot found the website that listed it)?? Just not sure and cannot measure the harness pins.
Pins are labelled but still need to know the voltages coming from the ECU and if it is a pull down sensor design. Anyone measure the pins voltages from the ECU harness? Using it to do some testing.
Thanks for the help.
PS I bought the sensor for $4 including shipping. New.
Old Nov 16, 2019 | 02:20 PM
I believe the crank position sensor is an inductor (a coil), there's two differential signal wires, no power. the ground is for the shield around the two signal wires. it produces a small AC current when the notches in the flywheel/flexiplate move past it.
Old Nov 16, 2019 | 06:39 PM
Jojog's Avatar
I measured the resistance cannot remember the pins as i am out. But they neasured 180ohms. So it is not a hall effect sensor but an inductive sensor that produces an AC signal; hence the 180ohms.
I will test it and see if i get an AC voltage from by running a metal object in front of it.
Old Nov 16, 2019 | 07:31 PM
lev's Avatar
lev
Yeah, buy a good OEM sensor, a $4 one won't cut it! It's a crucial part, one of very few that will stop a Volvo!
Old Nov 16, 2019 | 08:28 PM
Jojog's Avatar
It was $61 bucks and guessing on clearance. I bought it to test something.
busdude2
Apr 12, 2014 07:43 PM
ejpomeroy
Oct 4, 2011 06:06 PM
nascenta
Jan 23, 2010 11:21 AM
xt6turbo
Mar 23, 2009 12:30 PM
nicklitwin
Oct 10, 2008 01:14 PM
