oil leak 850
Old Feb 27, 2007 | 05:40 PM
lmjua's Avatar
Default oil leak 850
I have a 1996 850 GLT and noticed oil everywhere underneath the bottom of the engine. Any advice in locating the cause?
Old Feb 27, 2007 | 10:08 PM
JPN's Avatar
JPN
Default RE: oil leak 850
Greetings from Vermont.
Check the following locations:
1. Oil filler cap
2. Oil level dipstick
3. Oil cooler lines/connections
4. Oil thermostat (device located on the right of the crank pulley, where 2 oil cooler lines are attached to)
5. Oil filter
6. Oil pan gasket
7. Crank seal
Also, make sure to post your questions in the 850 section to receive more replies, people there are extremely knowledgeable & skilled.
Good luck,
JPN
Old Feb 28, 2007 | 09:23 PM
Clean the engine really good.
Then test drive and recheck for the leak.
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
