Orange antifreeze
Old Feb 22, 2009 | 01:26 PM
Michaelrose's Avatar
Default Orange antifreeze
So...my wife goes out and buys a 98 V70 non turbo with 94,000 miles on it confirmed by CarFax...One of the things that I noticed about the car is that it has that Orange anti freeze in it and I have heard horror stories about that stuff turning into jelly.
Is this true?....change it out to green?....Thanks
Old Feb 22, 2009 | 02:21 PM
On the Volvo's it should not do that.
But I would replace with Green coolant soon as most likely it has been in there for a while.
Old Feb 22, 2009 | 07:50 PM
GMad's Avatar
In the UK we have an organisation called the BSI (British Standards Institute), which covers everything that can be purchased on the consumer market.
Now then, anti freeze. There are dozens of different brands available here! Ones from the manufacturers and aftermarket varieties. Over here genuine GM anti freeze is orange, extremely good value and a good price. Ford genuine stuff is deep blue, also very good but pricey, aftermarket stuff is blue,green,orange,yellow, infact allsorts of colours, but as long as it has that BSI mark on the label, it's been tested more than an over active prostitute.
Sorry to ramble here but, I'm guessing things are different in the USA?
Old Feb 23, 2009 | 10:33 AM
JPN's Avatar
JPN
In the United States the most popular colour is green. Toyota seems to use red often, I've seen Suzuki (Korean KIA OEM) uses blue in some of their models, and others seem to use yellow, though very rare.
As long as there is no sign of rust (scale, debris, etc...) I would assume it is fine but if the car does not have full service record and if you're not sure when the last flush was, I would have it replaced with a name brand's 50:50 mix. I would not buy a pre-mix solution as it is a rip-off. I change my coolant at every 30,000 miles or 3 years, or 60,000 miles or 6 years for new generation, extended life coolant.
JPN
Old Feb 23, 2009 | 05:47 PM
malaka's Avatar
GM silica free antifreeze is orange. Why? Who knows? Toyota I once had used marischino cherry red antifreeze. The problem with silica free antifreeze is/was that some makers thought it would last 120K miles. Oops. Sort of like the old days when people thought Mobil 1 was absolutely good for 12K miles. Oops, again.
You don't know when this was changed, right? Except at least once in 94K miles. Change it. That's cheap insurance. After all, I just might be melted orange Popsicle juice!
Old Feb 24, 2009 | 11:06 AM
I had the anitfreeze tested and it has a PH of 6.0....so it is getting changed today....to the Green Stuff!!
gastate9
Aug 8, 2009 12:24 AM
New Daddy
Dec 10, 2008 10:23 PM
jollygoodgold
Dec 5, 2008 04:01 PM
ledzep526
May 1, 2008 08:32 AM
m1964
Sep 12, 2007 09:57 PM
