Antifreeze
Old Dec 5, 2008 | 11:40 AM
jollygoodgold's Avatar
Default Antifreeze
Hey guys.
I have a 96 850 Turbo. I was wondering what antifreeze you suggest and how many gallons should I by to do a flush? Also, do you suggest running a hose through it to wash some of the gook out or just replace the fluid? Thanks guys!
Old Dec 5, 2008 | 12:57 PM
Default RE: Antifreeze
Just drain and refill the fluid.
Buy a Brand name coolant and you will be fine. You should need about 2 gallons of mixed already stuff. If you buy and mix 50/50 yourself then one gallon.
Just do not buy the Dex Cool coolant.
Old Dec 5, 2008 | 01:06 PM
outdoor7or24's Avatar
+1 what tech said.
I have done the system - drain, fill with fresh water, run for 10 mins, drain, fill up with coolant mixture.
Seems to have worked just fine for me.
Old Dec 5, 2008 | 01:43 PM
wheelsup's Avatar
I bought this seemed to work OK
Out of curiosity why not Dex-Cool? Is that specific to GM only?
Old Dec 5, 2008 | 01:49 PM
wheelsup's Avatar
OK did some research, if you add Dex-Cool to our glycol based antifreeze you get a jello substance! Yikes!!
Old Dec 5, 2008 | 01:57 PM
The Dexcool was designed for a GM car only. I think 1 or 2 other car company's out there use it as well.
Thats why I said do not buy it.
Old Dec 5, 2008 | 02:15 PM
wheelsup's Avatar
yeah I was just curious, Ive seen it around and wondered what the difference was
Old Dec 5, 2008 | 04:01 PM
JimBee's Avatar
I checked with the local Volvo dealer on this; their parts clerk who has worked there for years told me they use Prestone and change it every 30,000 miles.
gastate9
Aug 8, 2009 12:24 AM
Michaelrose
Feb 24, 2009 11:06 AM
New Daddy
Dec 10, 2008 10:23 PM
ledzep526
May 1, 2008 08:32 AM
m1964
Sep 12, 2007 09:57 PM
