Rotor sizes
Old Dec 10, 2022 | 03:33 PM
tomkocz's Avatar
Smile Rotor sizes
Have a 2019 XC40 - I want to replace brakes & rotors. I am not sure how to find the rotor size before I order (in mm) as there are several sizes.
Help
Old Dec 10, 2022 | 10:23 PM
a couple choices of what to do 1) check the existing rotors for stampings on the outer rim that would show the size 2) measure what you have - the sizes are different enough so you should get a best guess 3) shop or call a dealer store with your VIN - example:
https://usparts.volvocars.com/p/Volv.../32300122.html
Old Dec 11, 2022 | 07:49 AM
tomkocz's Avatar
Default Thanks
very good information- Thanks
Old Mar 28, 2023 | 08:56 AM
tomkocz's Avatar
Hi
I called the dealer gave them the VIN. They say we have (for 2019 XC40 T5 Momentum) we have 17 inch rotors. I ordered them, Tried to put these on and they appear to be too big (exisitng ones are smaller). I called dealer back and they gave me the same measurements. I'm confused?? They say I need Volvo part 32300122 for front rotors - these are same that did not fit.
When they say these are 17 inch rotors - what measurement is that - the diameter of the rotor or circumference or what??
Any help greatly appreciated.
thank you
Old Mar 28, 2023 | 10:30 AM
Dingus1's Avatar
the 16/17/18inch refers to your wheels/brake package I believe, but I could be wrong. Your rotors will be in diameter given in millimeters. 296/322/345 respectively . Like mt6127 said, the existing size should be stamped on the rotor.
31471414 for 16inch
32300122 for 17inch
31471752 for 18inch
Old Mar 28, 2023 | 11:00 AM
seach the board for a recent related thread which offered a clue as to your size based on the caliper/pad clip design. Post up if that hack works for you.
Old Mar 28, 2023 | 01:19 PM
tomkocz's Avatar
OK - well the all say I have the 17 inch package - I received the 345 mm package (18 inch) which I thought was correct.
I presume back rotor /pads are all the same for 2019 XC40 T5 Momentum??
thank you
Ravishah89
Jan 14, 2020 02:26 PM
Mrclean67
Jun 28, 2017 05:59 AM
Micror
May 13, 2016 10:48 AM
snulma1
Feb 14, 2009 11:04 AM
firechicken99
Jan 15, 2009 02:08 PM
