s80 t6 code p0345 problem
Old Oct 9, 2012 | 06:25 PM
jdiego74's Avatar
Default s80 t6 code p0345 problem
hi there after replacing cam seals now im getting a code p0345 any one there knows if my computer has to be flash??? allredy check my timing marks also built a cam holder bracket..... lined up on back of the cams,, pulleys allingned with the upper cover and crank line up with the little mark on the block....also switch cam sensor front to back and still getting same code has power and ground and also signal is same has the cam sensor on the intake side... any ideas??
Old May 8, 2015 | 09:11 AM
Bryan Truxell's Avatar
I just had the same thing happen. You or anyone else figure this out? ?
jimcashin89
May 2, 2012 12:44 PM
Elsid
Sep 9, 2010 08:42 AM
dipfrog
Mar 13, 2010 02:18 PM
badmonkey
Jul 28, 2008 09:15 PM
gzh
Mar 21, 2007 09:29 PM
