Seat belt stuck
Old Jul 23, 2008 | 02:30 PM
JMorse's Avatar
Default Seat belt stuck
I have a 2002 S70 AWD that has a stuck seat belt. It's the passenger seat on the drivers side. There is no slack that can be fed back into slot that's up near the rear window. When I pull on it...it's locked up tight.
I had the same issue on the other side for just a brief moment, but then it started working again. I normally have booster seats back there for my kids. I removed them to haul some grown ups around and thats when the issue started.
Anyone know how to get this working again?
Thanks,
Jeff
Old Jul 23, 2008 | 07:09 PM
Default RE: Seat belt stuck
You can try unbolting the bottom of the belt from the floor and give a little slack and see if it works from there.
Old May 7, 2009 | 05:19 AM
Thumbs up Rear Seat Belt Stuck...
My rear center seat belt was stuck on my 95' 850. I was able to move it to the side to lower the seatback. When I did, I had just enough slack to retract the seat belt enough to get it loose. Did not have to remove the lower bolt.
Old May 7, 2009 | 05:58 AM
james786's Avatar
Hi,
Seat belt is important to driving car or any vehicle to put that seat belt. I had the same issue on the other side for just a brief moment, but then it started working again.
Austin apartment finder
anadrol
tucker98
Jun 18, 2012 09:34 AM
simonmeridew
North East
Sep 11, 2010 05:25 PM
windhamearle
Feb 8, 2009 09:06 PM
maichel
Nov 19, 2008 08:45 PM
rene
Jan 19, 2008 11:32 PM
