Seeking economic solutions (posted 4-month ago)
Old Oct 7, 2010 | 11:28 PM
Mama's Avatar
Default Seeking economic solutions (posted 4-month ago)
Hi there,
I am a elementary school teacher and my great 1990 Volvo Turbo wagon is starting to fall apart! I cannot afford to give it to my mechanic for costly repairs...meanwhile, I am driving to school in an unsafe car. I would be grateful for any advice on how I might be able to economically fix these repairs myself:
  • the driver seat belt no longer clicks in the seat belt thing
  • my rear driver's light is partially crushed from an accident and I believe I need the whole unit replaced
  • need new side headlights
  • the red brake light sometimes comes on....what is this?
Thanks so much for reading this,
Sarah
Old Oct 8, 2010 | 02:28 PM
jks2's Avatar
Most of the things you noted are items that could be picked up rather inexpensively from variuos sources, ebay, salvage yards, etc. These things are fairly easy to install.
I'm not sure what you mean with bullet #4. More information would be helpful.
Old Oct 19, 2010 | 12:12 AM
austinsmith's Avatar
Welcome aboard! Its good to see you in this forum.its full of information and knowledgeable members.You'll get lots of details from here.
Old Feb 13, 2011 | 08:28 PM
JPN's Avatar
JPN
1. the driver seat belt no longer clicks in the seat belt thing
The latch is stuck for FOD/other reasons. If not, replace it with a new unit.
2. my rear driver's light is partially crushed from an accident and I believe I need the whole unit replaced
Junk yard/On-line vendor should give you options.
3. need new side headlights
Same as #2.
4. the red brake light sometimes comes on....what is this?
One of the followings:
- The parking brake is not fully activating the Brake Light.
- The front/rear brake rotors are worn to limit.
- The brake fluid is getting low (NEVER just add brake fluid; check the condition of the brake rotors first).
JPN
Old Feb 23, 2025 | 03:25 AM
2kv70xc's Avatar
Default Reply:
Originally Posted by Mama
Hi there,
Sarah
Im new on the VF, it’s late and can only give quick suggestions.
Seat belt buckle thing…. Go to Junk yard, cut a valid buckle off….. and sew it or copper rivet it in place.
If you have to have those lights done….Autozone should get you all the correct bulbs, I’ve even coaxed them into putting them in for a tip.
good luck keeping her roadworthy.
Rick from Virginia
Jan 31, 2012 07:12 AM
TheTrainwreck
Oct 9, 2010 08:18 PM
ricpot
Dec 21, 2008 05:40 PM
jcmartin
Apr 26, 2006 09:31 PM
