Shimmy at High Speed!!
Old Mar 15, 2010 | 11:00 AM
01S60's Avatar
Default Shimmy at High Speed!!
I have a 2001 S60. When at highway speed there is a severe shimmy felt through the steering wheel and the whole car, when under torq. Take my foot off the accelerator at it almost clears up. I have suggested to the dealer hubs but they tell me they are ok. Anyone have a an idea what may be causing this severe shimmy???
Old Mar 15, 2010 | 01:47 PM
Tires. Get them rotated and balanced.
Old Mar 15, 2010 | 02:43 PM
01S60's Avatar
Default Been there, done that!!
I have had the tires changed and balanced.
Old Mar 15, 2010 | 10:22 PM
How long ago? Some tires need to be balanced every 3,000 to 5,000 miles.
Old Mar 16, 2010 | 03:13 AM
Typhoon's Avatar
You could have lateral run out on a wheel or tyre. Try rotating front to rear. Putting the spare on teh front will also help, spares never get damaged so are usually the best rim on the car.
Is it a high frequency shimmy, very fast? If so, look at tie rod ends, steering rack ends and steering rack secured to chassis properly.
If lower frequency, look at lower control arm bushings or radius rod bushings if you have them.
If it's under power, also suspect poor strut damping or strut top bushes, and even a worn engine mount can set up a torque whip in a driveshaft that feels like a front end problem.
Regards, Andrew.
itr
Nov 22, 2010 07:05 PM
01S60
Mar 29, 2010 10:01 AM
zilinski6605
May 12, 2006 10:00 PM
Russen
Mar 31, 2006 09:50 PM
89740gle
Apr 21, 2005 04:37 PM
