Strut Pierces Through Hood!!!
Old 01-01-2015 | 08:27 PM
John Ligda's Avatar
Default Strut Pierces Through Hood!!!
Hi,
This is in regards to a 1998 v70 which was purchased by a family member about a year ago. I just found out that about three months ago the struts started poking through the hood!!!
Anyone see this before. (see pics)
The mechanic he bought the thing from said he did not think it was dangerous and would price new struts and fix it. Has anyone seen this or have insight as to why it would be happening? Where they installed incorrectly or are they cheap parts? This can NOT be the normal wear and tear of this car.
Attached Thumbnails Strut Pierces Through Hood!!!-imag0073.jpg   Strut Pierces Through Hood!!!-imag0067.jpg
Old 01-02-2015 | 02:40 AM
migbro's Avatar
Oh, really.
So a family member has been driving it for three months like this? After ignoring the warning signs of impending failure for nine months?
The good news is your mechanic is correct. New struts and strut mounts and you'll be all set.
Front Strut Mount Failure
All 1993-2000 850, S70, C70 and V70 models use a rubber encased upper spring seat/strut mount that suffers from premature failure. Symptoms of a strut mount that has failed or is on the way out are creaking/groaning sounds during low speed turning. You can also visually inspect the mounts from the engine compartment and looks for signs of the rubber pulling away from the center sleeve or for signs of cracking. If left unattended, the noise can turn into clunking or worse if it fails completely, the strut shaft can break through the mount and damage/dent the hood of the car. IPD developed a heavy duty version of the strut mount using a stronger more durable rubber that comes with a 2 year warranty and is considered a must do upgrade any time you have the front struts apart.
Old 01-02-2015 | 06:17 AM
pkrface's Avatar
Two people should be shot here. The person who continued to drive it like this and the mechanic who said "it's not dangerous". Geesh
Old 01-02-2015 | 08:36 PM
ES6T's Avatar
This is what happens when you ignore the crunching noise of a newly broken spring seat. Then ignore the loud clatter of a totally shot spring seat.
JeannieBeannie
03-06-2019 02:29 PM
MDUBBSS70
05-28-2014 10:02 PM
Red Tractors
08-20-2013 11:33 PM
ricky
02-28-2009 08:51 PM
850TurboWgnPlatEd
11-05-2008 01:52 PM
