Sun Visor replacement
Old Mar 19, 2015 | 06:09 PM
Dan O's Avatar
Default Sun Visor replacement
Hi all,
New owner here 2015 V60 T5 (love it) and am looking for help. Does anyone have instructions to remove and replace the driver sun visor? I did not get the option package that included homelink but can buy the homelink visor alone for 235.00.
Thanks!
Here is a pick of my new surf mobile!
Old Nov 11, 2017 | 11:32 AM
BobS1957's Avatar
Dont buy a new one for $235, the salvage yards are full of them and many Volvo trim parts are interchangeable. Go to Car-Parts.com and plug in your info, search for visor with homelink. Should be able to get one certainly under $99.
To install, remove the plastic tabs covering the two screws that mount the visor to the roof. Remove the 2 screws (one is torch and the other hex-head), pull the wire out until you see the connector, unplug it then reverse the process to install.
Should only take 10-15 minutes. Program the homelink - thats easy too, youtube has instructions but its basically simultaneously hold the homelink button and a hand-held remote for 5 seconds, done!
Old Sep 19, 2020 | 07:27 PM
Bryen C's Avatar
Hey, I did this but the plug In my s40 isn’t right for the homelink visor I grabbed at the junk yard. Is this fixable? Can I update or change the plug to allow the homelink visor to work in my non homelink version?
Old Sep 24, 2020 | 10:07 AM
BobS1957's Avatar
My driver side visor had power as there is was a mirror with light built in, it did not have Homelink. I purchased a visor with Homelink from an online junk yard and simply unplugged the old, plugged in the new and the Homelink worked fine. No other changes were necessary.
Hope this helps.
Old Nov 6, 2023 | 04:31 PM
PamSordet's Avatar
Default How to remove tabs
I know this is an old thread, but I’m trying to replace one of the sun visors on my 2015 XC70…how can I remove the plastic tabs covering the two screws that mount the visor to the roof?
Any help would be greatly appreciated.
Old Dec 10, 2023 | 12:06 PM
LLC's Avatar
LLC
Insert a skinny flathead screwdriver in the crease, and the covers will pop out.
Old Mar 11, 2025 | 09:14 PM
dlxc60's Avatar
Default Tips to Replace Sun Visor
In order to replace the Sun visor, you need to not only remove the phillips screw and 8mm bolt behind the two plastic tabs holding the visor in, but also the two 8mm bolts holding the grab handle, and the one 8mm Bolt holding the A pillar. You need to slide the A pillar off in order to pull the headliner down because the clip for the installation of the new visor is taped to the headliner and you can only access it if you pull the headliner down. Did this on my 2013 Xc60. Before you do any of this work, you must disconnect the negative battery terminal. You will be working near the airbag on the A pillar. There are videos on YouTube showing how to remove the A pillar.
Newport_j
Jun 9, 2014 09:51 AM
ajahn
Sep 1, 2011 10:00 PM
rocfob
Dec 17, 2008 10:28 AM
Pretorien
Dec 9, 2008 10:06 AM
jdennis
Mar 27, 2006 03:24 PM
