Sunroof calibration on xc60 early 2015
Old Aug 27, 2020 | 11:56 AM
Ben Mans's Avatar
Default Sunroof calibration on xc60 early 2015
Hi I hope some can help me, for the 2nd time since I had the car, the sunroof won't fully close, then it causes wind noises, does any one know what the reset and calibration procedure is
Old Sep 1, 2021 | 09:47 AM
dlxc60's Avatar
Default 2013 Sunroof Won't Close
The fix I saw online was to was to turn the vehicle off. Put the Ignition in position 1, open the sunroof to the tilt position and then pull the tilt close button and hold until you hear it recalibrate. I was told this would take 5 seconds. But nothing happened. Here's what I did. With the engine running, I opened the sunroof to the tilt position and then pulled the close button-down for over 20 seconds and the sun roof finally recalibrated and closed completely flat. Hope that helps you.
Kimbaland
Feb 18, 2019 08:30 AM
Flavio Picosse
Oct 8, 2018 05:31 PM
thomhanes@gmail.com
May 7, 2018 07:18 PM
ShaunWaves
Feb 18, 2017 10:49 PM
JBxc60
Mar 29, 2016 07:53 PM
