Tech help!! Window stop programming
Old Jan 8, 2010 | 08:22 AM
Cecil0Lancaster's Avatar
Default Tech help!! Window stop programming
Hi Guys,
I am new here, and needs some help.
My Driver side window was replaced, but the installer could not set the stop for the "one touch up".
Using that, the window winds all the way up, but then down again. Manually it works OK.
For down it it stops about 25mm from open, again manually it is OK.
Initially I assumed that the position sensors got disturbed, but the installer pointed out that these things are noadays computer controlled, and the programming of the car's computer needs to be adjusted.
He tried pressing and holding buttons etc. but failed to find the correct trick.
If anyone perhaps had a similar experience, and found the solution, kindly share it with me otherwise I will have to take it to the agents.
The cost is not the problem, the glass guy will pay, but the sclep!!
Regards
Cecil
Old Jan 8, 2010 | 08:11 PM
If the holding the switch up for 5 seconds after it stops and doing the same for down did not work then the Dealer is needed.
Old Jan 9, 2010 | 04:26 AM
Thanx Tech Admin,
I have tried, but to no avail!
Maybe I did something wrong.
I assume the ignition must be swiched on and remain on throughout. Any other requirements? Door closed etc?
I wound it up to the top manually, rested the switch and then held in up position up for 5 secs.
Then wound it down, manually, rested switch, and then held in down position for 5 secs.
Please be patient with me.
Regards
Cecil
Old Jan 9, 2010 | 10:45 AM
When going up and the window hits the upper limit keep holding the switch for the 5 seconds after it stops.
Old Jan 11, 2010 | 04:14 AM
Thanx,
I have tried but no success.
Took it to the dealer,re-initialised the module or such.
Fortunately they were friendly enough not to charge anything, it only cost me the travelling there, and waiting for them to get around to it.
Regards
Cecil
Old Jan 11, 2010 | 06:45 PM
Glad it is good now.
bit_eimer
Jun 11, 2017 10:09 PM
muckster
Dec 31, 2014 12:56 PM
pnhons
Nov 20, 2011 05:26 PM
boycebell
Jan 25, 2007 07:17 AM
sudvam
Oct 30, 2003 12:56 AM
