Timing Belt
Old Sep 7, 2013 | 11:37 PM
beachbumz's Avatar
Default Timing Belt
Hello All,
I own a 2004 Volvo s60 2.4ltr . I'm not sure if the Volvo had the 105,000 timing belt replaced. Is there a easy way to look in there and see the condition of the timing belt to see if it has any cracks in it or not. A belt not changed by 116,000 miles I would think would have cracks in it if it by then and would be able to tell if it's newer or older.. Am I correct in this assumption. Thank you, Bill
Old Sep 26, 2013 | 09:45 AM
go-part's Avatar
Former Sponsor
Old Sep 26, 2013 | 12:06 PM
Bill, check your owners manual. It will tell you when it should be changed. And, NO you really can't tell be looking at it. There is no bend sharp enough to see the cracks. Change it before it's to late.
Old Sep 26, 2013 | 02:02 PM
ES6T's Avatar
Actually, you can easily see the cracks where it wraps around the can pulleys. Just pop the top cover off.
Old Sep 26, 2013 | 02:37 PM
John Arsenault's Avatar
I have to agree with rspi on this one , it would be to hard to tell visually if it was going to fail anytime soon just by looking at the belt while it is installed. If you can see any cracks by inspecting it by all means change it, but just don't think because you look at it and don't see cracks that it won't fail. Thats not a chance worth taking.Once you remove a belt you can fold it over and see cracks that you never would have seen unless you folded it over.
Old Sep 26, 2013 | 02:42 PM
ES6T's Avatar
If the belt is original with 116k on it, it will be obvious.
Old Sep 26, 2013 | 06:12 PM
Good luck with that.
7zarc7
Mar 24, 2010 07:17 AM
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
