trans problems
Old Oct 6, 2020 | 10:41 AM
mike s's Avatar
Default trans problems
I have a2004 xc70 that has the normal hard shifting between 1st and second and third. I've change the oil and it helps for a while is there a more permanent solution besides tran rebuild
Old Oct 6, 2020 | 01:32 PM
You could replace the valve body, that MIGHT fix it. Others will claim you can rebuild the solenoids yourself on the valve body, that MIGHT fix it. I trust you used the correct oil, 3309, or volvo, or Toyota type 4 (and others). Just not some generic that claims to be compatible.
scubatelco
Dec 8, 2011 08:19 PM
Rob G.
Mar 29, 2011 07:42 PM
gabyman97596
Jan 1, 2011 12:32 PM
sundavil7
Oct 29, 2008 10:28 PM
eliezer
Jan 12, 2008 05:00 PM
