Transmission fluid
Old Jan 17, 2014 | 11:12 AM
ibanez958's Avatar
Default Transmission fluid
does anyone know if the Toyota WS tranny fluid equivalent to the Volvo oem fluid for the AW55-50??
Old Jan 17, 2014 | 05:30 PM
difflock54's Avatar
I have read that Toyota WS is for vehicles 2004 or newer. (needs confirming)
Also for fully sealed transmission systems.
An AW55-50 transmission is supposed to have a JWS3309 rated fluid.
You can use Toyota T-IV, Mobil 3309 or synthetic Mobil 1-3309.
Several other fluids state they are equivalent to JWS 3309 also but check their spec's carefully if selecting one of these.
Toyota T-IV is cheaper than Mobil or Volvo ATF but is a very popular choice.
AW transmissions are a Toyota designed unit.
Old Jan 17, 2014 | 05:36 PM
ES6T's Avatar
Correct. Anything meeting JWS3309 specifications works.
But it is not designed by Toyota. Aisin Warner makes them, hence the "AW"
Old Jan 17, 2014 | 05:45 PM
difflock54's Avatar
This link basically outlines Toyota Motor corporations involvements with Aisin warner tranny's.
They strongly influence the manuf' / design of these transmissions.
List of Aisin transmissions - Wikipedia, the free encyclopedia
Old Jan 18, 2014 | 11:14 AM
ES6T's Avatar
Kinda vague, but interesting.
Old Jan 19, 2014 | 06:57 AM
ibanez958's Avatar
so has anyone tried?
Old Jan 19, 2014 | 09:38 AM
ES6T's Avatar
Is it JWS3309 compatible?
Old Jan 19, 2014 | 07:46 PM
difflock54's Avatar
Well, unless their (Toyota's) technical spec's specifically state WS meets JWS 3309 requirements I would not use it in a pre 2004 vehicle or a one without a fully sealed transmission.
I would stick with the T-IV or a known JWS 3309 compliant fluid.
The AW 55-50 is not a fully sealed transmission.
Old Jan 21, 2014 | 01:03 AM
carlxc's Avatar
The viscosity of WS is much lighter than T-IV so I wouldn't do it. And the fact that WS is for JWS 3324 and not for 3309.
Old Jan 21, 2014 | 08:59 AM
ibanez958's Avatar
then what about the T-IV, has anyone try it yet?
Old Jan 21, 2014 | 04:34 PM
difflock54's Avatar
read post # 2 above.
Many forum members are using T-IV for their AW transmissions.
You should find it cheaper than Volvo ATF also.
Go for it.
AustinPower
Nov 11, 2008 07:43 AM
flyingo
Apr 27, 2005 07:19 PM
94volvo850
Feb 18, 2005 06:49 PM
