Trip computer "INFO" switch questions
Old Sep 11, 2008 | 08:56 AM
nightlog's Avatar
Default Trip computer "INFO" switch questions
I bought a trip computer/harness/"INFO" switch combo from someone on eBay. The switch is more squared in shape compared to the other rounded switches in my 1995 850 GLT. The back says Volvo 3523260 and ALPSJapan 4970. Is this just an older OEM switch or a replacement part? (I have heard the switches can go bad after a while.) If it isa more desireable part, I will keep it - if not I would like to know so I can justify buying another one that matches the rest on the dashboard. Thanks
Old Sep 11, 2008 | 04:36 PM
billofdurham's Avatar
Default RE: Trip computer "INFO" switch questions
That part number was used from 1992 - 1994.
From 1995 on the part number is 9128543
Old Sep 12, 2008 | 08:05 AM
nightlog's Avatar
Thank you, sir!
Old Sep 21, 2008 | 01:43 PM
nightlog's Avatar
I picked-up a newer switch to match the others, installed it and the instrument display - they work like a charm.
Is the switch supposed to be backlit because mine isn't.
Old Oct 2, 2008 | 10:56 PM
robrike's Avatar
I did the same install into my 97 and the switch on mine is not backlit. The display is but the actual switch with dial is not.
Rob
97-850Wagen
Sep 4, 2013 03:30 AM
sly_fox
May 8, 2011 01:40 AM
nightlog
Oct 22, 2008 02:20 PM
fritzlovesmary
Feb 23, 2008 01:51 PM
fritzlovesmary
Sep 24, 2007 01:02 PM
