Try to remove a bolt to repair Power Steering Flat Plate
Old Apr 25, 2009 | 09:04 AM
lmchle's Avatar
Default Try to remove a bolt to repair Power Steering Flat Plate
Can someone please tell me how to remove the bolts to replace my old flat plate with a new one? I've sprayed WD40 on it and I still can't remove the old bolts. I've gotten one off but the last two is very hard to come off. I've let it sit overnite with the WD40 but still bolts want unscrew. Is there another lubricate I can use to make this easier. HELP!!!!!!!
Old Apr 25, 2009 | 09:18 AM
Which bolts are left?
They should loosen right up.
Old Apr 25, 2009 | 10:24 AM
bearhauler's Avatar
Can't give you a Volvo specific answer; but the best chemical spray I have found for loosening stubborn bolts is a product called PB Blaster. Most auto parts stores will have it.
Old Apr 26, 2009 | 11:21 AM
lmchle's Avatar
2 bolts are left. the 2 bottom
Old Apr 26, 2009 | 11:22 AM
lmchle's Avatar
Do I need to let the PB Blaster sit on it
Old Apr 26, 2009 | 12:48 PM
01_fast_ride's Avatar
I use that stuff on everything. Its great stuff. You should not have to wait long for it to work. You might just need more leverage.
Old Apr 26, 2009 | 07:43 PM
Did they come loose yet?
Old Apr 27, 2009 | 08:08 AM
lmchle's Avatar
no they hanen't
Old Apr 27, 2009 | 07:17 PM
Wow did you try a bigger breaker bar yet?
Stephen O'Grady
Apr 7, 2012 04:34 PM
dekaband
Jan 2, 2011 04:21 PM
T5_AWD_05
Aug 5, 2010 06:04 AM
richsid
Apr 3, 2008 09:02 PM
emoney1320
Oct 2, 2007 09:58 PM
