Broke bolt torqing p. plate! help
Old Oct 2, 2007 | 11:14 AM
emoney1320's Avatar
Default Broke bolt torqing p. plate! help
I was replacing the clutch on my 81 240 and on the final torquing of the pressure plate bolts I managed to snap off the head of one of the bolts. The head came clean off, and the rest is stuck in the flywheel. Should I just remove the flywheel and drill it out, and then re-thread it? Any ideas?
Old Oct 2, 2007 | 02:27 PM
Beardog's Avatar
Default RE: Broke bolt torqing p. plate! help
Remove the fly wheel so that you have access to the bolt. Try a small bolt puller first, before you rethread it. Drill a small hole and then use the smallest puller you have. hopefully you drill straight so that you don't have to rethread.
Old Oct 2, 2007 | 05:59 PM
ORIGINAL: Beardog
+1
Old Oct 2, 2007 | 09:58 PM
wojeepster's Avatar
If they are through holes take flywheel off center drill bolt and drill from behind. The drill will naturally unscrew it.
Stephen O'Grady
Apr 7, 2012 04:34 PM
Counselor828
Aug 22, 2011 12:19 PM
dekaband
Jan 2, 2011 04:21 PM
lmchle
Apr 27, 2009 07:17 PM
JimKW
Mar 19, 2007 03:26 AM
