Hit a curb...had a flat, steering wheel not aligned
Old Mar 25, 2008 | 01:38 PM
richsid's Avatar
Default Hit a curb...had a flat, steering wheel not aligned
Hi:
I hit a curb at 20-25 mi/hr and immedieately the left front tire had a flat (the kind that can not be repaired [&:]. I installed a full size spare that I had in my trunk but noticed that now my steering wheel is crooked ie if I were to striaghten my steering wheel the car goes to the left. I have let the steering wheel go at the freeway speed and also while braking and my car doesNOT 'pull' in any direction. I definitely have to get the wheels balanced (at least the ones on the left- driver side) what else could be wrong? Even if the car does not pull could my alignment be off and will getting the alingment fix the steering wheel? Do I need to worry about suspension or any other components? Thanks...
Old Mar 25, 2008 | 01:41 PM
Bigtrev's Avatar
Default RE: Hit a curb...had a flat, steering wheel not aligned
You probably bent something like a tie rod. Worst case damage to steering rack. It definately will need an alignment along with any repairs for bent parts. Do you have any warning lights on like the SRS light or airbag light? If so then you might have knocked the steering wheel module out of calibration. If you take it to a shop just tell them to check the steering since you hit a curb. I'm pretty sure you bent the outer tie rod.
Old Mar 25, 2008 | 05:34 PM
richsid's Avatar
No SRS light but yesterday and a day or two after I hit the curb my "ABS" light came on and stayed on for a while but went away...Thanks for you reply.
Old Apr 2, 2008 | 09:33 AM
Hudini's Avatar
The spare could be low on pressure too. Check that first.
Curbing a tire hard enough to damage it could easily damage a tie rod too.
Old Apr 3, 2008 | 02:34 PM
mcguij1's Avatar
definitely get the whole front end looked at and dont ride on that spare too long
Old Apr 3, 2008 | 09:02 PM
richsid's Avatar
Thank you all for your kind replies. It is in the shop being looked at...
vrhs2011
Nov 4, 2011 06:12 AM
brgbldr
May 28, 2009 12:43 AM
poor_red_neck
May 18, 2009 02:03 AM
tpf
Sep 3, 2008 06:31 PM
