Turbo went in 07 car...why? plz help!
Old Sep 4, 2011 | 11:24 AM
vinnie-volvo's Avatar
Default Turbo went in 07 car...why? plz help!
Hey guys,
Hope you can answer these (esp 1st one)
have 2 questions...
Can anyone here tell me exactly why a turbo would just die in my 07 s40 volvo only 55,000miles up on it...
Also, in cold weather should i wait few seconds before starting up my diesel engine or should I always wait for few seconds regardless of weather as its diesel?
Old Sep 5, 2011 | 07:50 AM
Exclamation The fastest way to kill a turbo
Turbo's have a driving care procedure that should be followed. You can read up on it in the owners manual. The life of a turbo is a back lash of the motor care. Here are my top suspicions in order of wear danger.
  • Never rev a cold motor, this would be a extreme killer for a turbo. A turbo needs to be warmed up and well lubed before you put a demand on it. I never rev my car before the temp is all the way up.
  • Never rev a motor right before you shut it off. A turbo should be allowed to cool down before the motor turned off to avoid over heating and cooking of the oil in the turbo. I always drive or idle at least the last 2 miles of my drive, especially if I had been driving hard.
  • Never exceed oil change recommendations. If I drive hard, I will likely change the oil sooner. This is why a lot of hard drivers change oil every 3,000 miles instead of the recommended 5,000 miles.
  • Always use high quality oil, synthetic preferred. Note: Even with synthetic I do NOT exceed oil change recommendations.
  • Always use good quality oil filters.
  • Always fix oil leaks, especially those that involve the turbo.
Other than what is mentioned above, any part can go out on a car at any time. That's why we have warranties on new cars. A turbo should last 200,000 or longer. I don't know if they go much longer than that. It would be interesting to see if anyone has more miles than that on one without a rebuild or anything.
As for the diesel, just do what the owners manual recommends.
Old Sep 9, 2011 | 03:31 AM
Default Smell of fumes in car
Thanks rspi! That was interesting. New turbo going okay so far...i think!!!
However One thing ive noticed since the turbo was fitted is when I start the car Im finding a strong smell of fuel coming into the car. I'm not sure where it is coming from but it is quite strong...what's the reason for this Im a bit clueless to when it comes to cars!
Old Sep 9, 2011 | 08:29 AM
Usually a fuel smell is due to a loose or torn vacuum elbow. You can start the car and search for it with a lit match, but it's probably best to disconnect every vacuum elbow you can find and look it over.
VOLVO15
Sep 21, 2009 04:51 PM
jdseattle
Dec 31, 2008 08:04 AM
Boosted_s80
Oct 23, 2005 03:42 PM
