Urgent Service of Airbag restraint system message
Hello Every one.
I drive a Volvo 2004 XC90.
My battery went dead. After installing a new one. I got a Message on the dash that my airbag restraint system needed urgent service. I Used FIXD that diagnosed that the car computer system had no codes to address, yet the message persists.. Have tried to erase that message, but it still appears
I have tried to reset the message using you tube instructions , but, no fix. I am reaching out to the Volvo Forum for help
Anyone had the same or similar problem and know how to fix the bad message.
Thank you for suggestion . I have used a FIXD and an independent mechanic's scanner and on Both scanners, no codes come up. I seemst that the restraint system has no problems, other than the message appearing in the message center. . I have tried to clear that message multiple times using the method shown on you tube videos, but it doesn't clear..
Any other suggestion ? Thanks, D
If both of those will talk to SRS - you may need one of these, look at the bottom of the page under "common failure symptoms"
https://xemodex.com/us/product/drive...epair-service/
troutie
2001-2013 model year XC70
04-14-2020 10:24 AM
