Urgent Service of Airbag restraint system message
Old Oct 4, 2020 | 08:02 PM
rinconmn's Avatar
Default Urgent Service of Airbag restraint system message
Hello Every one.
I drive a Volvo 2004 XC90.
My battery went dead. After installing a new one. I got a Message on the dash that my airbag restraint system needed urgent service. I Used FIXD that diagnosed that the car computer system had no codes to address, yet the message persists.. Have tried to erase that message, but it still appears
I have tried to reset the message using you tube instructions , but, no fix. I am reaching out to the Volvo Forum for help
Anyone had the same or similar problem and know how to fix the bad message.
Old Oct 13, 2020 | 07:18 PM
Wayne Yen's Avatar
Volvo diagnostic is tricky. Some common OBD dongles cannot erase the DTC codes. You have to turn to professional diagnostic scan tools.
SRS airbag ID:
0x1dd01c01
0x737
if you can inject CAN messages into OBD port, try the followings:
read DTC: [above ID] 0x19 02 20
clear DTC [above ID] 0x14 FF FF FF
good luck
Old Oct 14, 2020 | 08:09 AM
That means there is a self diagnostic code stored in the SRS system - that is only (or commonly for normal folks) accessible with a compatible scan tool. You scan the car, read the code, write it down (in case it comes back soon) and try to erase it. If it goes away great - if not proceed to next step diagnosing problem.
Does your $39 FIXD read SRS codes? Or just OBD related emission codes? You have to read a code to be able to erase it.
If there are no codes with a compatible scan tool - you might need one of these, look down near the bottom of the page under "common failure symptoms" for srs warning light on problems
https://xemodex.com/us/product/drive...epair-service/
trek8288
Oct 8, 2023 09:54 AM
rinconmn
Oct 5, 2020 12:06 PM
troutie
2001-2013 model year XC70
Apr 14, 2020 10:24 AM
majorcode
Nov 10, 2014 06:41 AM
raygnlz
Jul 12, 2009 11:36 PM
