V70 A/C works after hitting a bump?
Old Jun 27, 2011 | 02:57 PM
jonathanvolvo's Avatar
Question V70 A/C works after hitting a bump?
I have a 2003 V70 wagon. The a/c blower has begun to work only sometimes. When it works, it continues to work as long as the car is running. If it doesn't work, it does not turn on when I turn the car on, however it may start working 1) If I hit a bump or 2) If I make a sharp right turn. It doesn't always start if I hit a bump or turn sharply, but if it does start after not starting, it is because of that. I initially replace the fuse even though it looked good and that didn't change what happens. The fan speed or a/c setting do not affect it. Also, bumps or turns do not cause it to turn off once it is running. I removed the blower motor and bench tested it and it worked with direct current. I cleaned it, replaced the cabin filter, put it back in and it worked... for about a month. I replaced the fan with a new one and still nothing. Looking at a wiring diagram, it looks like if it were the resisitor I could bypass it on high, but again it works or doesn't work on any speed.
Any ideas? I am in Florida in the summer and it's hot!!
blackbrick
2001-2013 model year V70
Aug 14, 2014 07:11 PM
bbensten
Jun 30, 2014 12:44 PM
Dionepsoc
Jul 20, 2009 11:17 PM
grand94jeep
Jan 6, 2007 05:05 PM
oragame
Jul 21, 2005 11:42 PM
