V70 Electrics going haywire !!
Old May 22, 2018 | 03:18 AM
andyturbodrive's Avatar
Default V70 Electrics going haywire !!
Hi, I have a 2004 V70 Automatic. 100,000miles and looks and drives absolutely as new . . . . . . . until, after doing around a 50 mile run the electrics go wierd. It starts by jerking a couple of times ( which I saw in the reflection on the car in front was the headlights going off and on ) Then the speedo array went totally blank, the wipers stopped working, no indicators, windows stopped working and when I stopped and set off again it was so sluggish as if in safe mode but once built up speed drove Ok at 70mph to get home ( still no indicators etc. ) When I did stop there were various clicks and buzzes from behind the dash and in the engine compartment. At home the central locking didn't work, but a few hours later everything working fine !! Done this once again, so only done short journeys, but the other day when the weather was really hot did same again after only 7 miles. Any suggestions as I have had to hire a car to go to a funeral as not sure if would get me there. Many thanks
Old May 22, 2018 | 11:53 AM
firebirdparts's Avatar
My guess would be this:
Trying to get to the bottom of my "mystery" problems... CEM failure in with heat...
Old May 22, 2018 | 12:02 PM
Here are some people who fixed it well and thoroughly, if it's the same issue
P2 Owners: XeMODex now fixes CEM & REM before they fail
Old May 22, 2018 | 01:23 PM
Thanks ever so much for that Firebird. It seems as if that is likely to be the problem. I did think it was perhaps due to something overheating but hadn't got a clue what. I will have a go at getting a fan and then go on a long run. Thanks again. Will post how I get on.
blazing17
Oct 1, 2011 06:48 PM
anneVA
Jul 5, 2010 11:57 AM
98T5
Oct 28, 2009 08:03 PM
rfrazier
Jun 14, 2009 01:20 PM
bjornagain
Aug 5, 2008 07:43 PM
