V70 White smoke????
Old Aug 15, 2010 | 03:10 PM
AndyT5's Avatar
Default V70 White smoke????
Recently bought a v70 t5 250000 on clock (don't ask y mad moment on eBay)
oil in water n vice versa , presure tested head n replaced head gasket
fired new timing belt , now after few minutes after start up White smoke comes from exhaust n if u rev it gets worse any suggestions ?
Old Aug 19, 2010 | 07:48 AM
If the head gasket was replaced maybe there is still some oil in water or vise versa. Were both systems flushed? If not, maybe it will burn off soon or check the systems for contaminates. Also, was the head warped/damaged?
Does "n" = "and". This site is NOT a text message. Spell things out so we can understand what you are writing.
Old Aug 29, 2010 | 09:19 PM
titaniums6025t's Avatar
also when you have oil contamination in your cooling system you really should replace EVERY hose that carries coolant as the oil ruins the hoses and will continue to coat the inside of your radiator, heater core and engine.
Wharf1999
2001-2013 model year V70
Jan 12, 2014 03:27 PM
v70euro
Nov 3, 2007 10:07 PM
Pv12345
Oct 11, 2007 08:33 AM
jay philoon
Nov 6, 2005 03:41 PM
cool_guy_jay
Sep 27, 2005 10:35 PM
