window passenger side
Old Aug 29, 2010 | 12:29 PM
sam1am's Avatar
Default window passenger side
the window came off track on the passenger side of my 2000 volvo s80. all the way off track now and looking in the door 1 of the 2 arms seems to be way lower than the other, like 2 low. it goes almost if not strait down 6 oclock in the rolled down completely position. doesn't look normal. i'm bout ta take off the motor since it's the only thing not pop rivited on and see if i can reset the arm positions unless there is a reason i shouldn't or somebody can tell me something i dont know .....which isn't much. i have tried putting those littlte square blue plastic pieces that you put the little metal pins on that go on the swing arm ***** that slide into the two metal backets attached to the window......but then when i went to go roll it the ****er popped off on me again. it was kinda a bitch getting that **** on there and obviously i'd think that arm position is why it fell off in the first place so.........
Old Aug 29, 2010 | 01:43 PM
Take the door panel off the oppisite side and compare to figure out what is really wrong. Until you are ready to fix it properly, get it up and disconnect a wire to the motor so no one rolls it down.
Old Aug 29, 2010 | 09:32 PM
ibanez958's Avatar
i won't even brother repairing it, just get a new window regulator. reason why is cuz, if it happen once, chances are it will happen again & again & more frequance. may as well fix it right the first time
Old Aug 29, 2010 | 09:34 PM
ibanez958's Avatar
btw, make sure u change the 2 sliding block along 2
jipsy
Jan 22, 2012 06:00 PM
sam1am
Sep 9, 2010 02:21 PM
dizzyd89
Apr 10, 2009 10:42 PM
850GLTWAGON
Nov 21, 2008 04:14 PM
hazard
Dec 23, 2006 02:03 AM
