Volvo 740 no compression on 3 cylinders
Old Jul 7, 2022 | 05:07 PM
Baileyf05's Avatar
Default Volvo 740 no compression on 3 cylinders
Hey! i just did a head gasket in my 1987 volvo 740 tic
It went really smoothly and it ran before, all i did was get the head resurfaced and a new headgasket, aswell as doing the hushers. When all was said and done i did the timing and everything lined up, but there was no compression on cylinders 1 2 3 but low compression on 4. im very confused because it ran before and the timing was 100% correct. any ideas.
Old Jul 8, 2022 | 01:23 PM
I'd double check the timing marks for starters. I'm wondering if the cam gear was installed wrong - so I'd check the B end of the cam to see if there's a timing mark there as well. You may also have dry cylinder walls so you can try dropping about 1 tablespoon of motor oil down the spark plug hole to help build compression.
Old Jul 8, 2022 | 02:31 PM
What are "hushers"?
Did you check the valve clearances?
SR Heer
Jan 5, 2022 04:04 PM
Zonkball
Nov 28, 2015 06:25 PM
JimS111
Jul 17, 2012 11:07 PM
enthuesd
Dec 27, 2008 07:05 PM
rockafella
Aug 6, 2007 08:48 PM
