Volvo b230fk
Old Mar 18, 2023 | 09:57 AM
Isac.olsson's Avatar
Default Volvo b230fk
Hej jag undrar om någon vet varför mina spridare inte får jord vi har testat olika grejer så som olika jord punkter och alla relä som ska gå till spridarna och dom funkar som dom ska så vi lutar mot att det är styrenheten så vi köpte en ny men spridarna får fortfarande inte jord det hadde varit jätte tacksamt om någon som vet lite mer om volvos en vad vi gör som kan hjälpa oss tack för mig.
Old Mar 18, 2023 | 10:55 AM
PixelDust's Avatar
The Google translate of Swedish to English is hard to interpret, but I think you're talking about injectors right?
Okay. First, start with your fuel pumps. In tank, and under the car. Do they have power and ground? Will they activate when supply 12v directly? If they're good, next check your fuel pressure and do a volume check. I'm gonna insert a page from the Bentley manual. Hopefully this helps
Old Mar 18, 2023 | 02:57 PM
thanks for fast awnser and we know that the fuel pump is good and is working we get fuel up to the fuel rail but the injectors dont shoot the fuel into the motor and we changed the injectors to injectors we know work
Old Mar 20, 2023 | 05:31 PM
PixelDust's Avatar
Are you getting power to the injectors? Sorry for the delayed response.
Old Mar 21, 2023 | 07:56 AM
yes im getting power to the injectors
Old Mar 24, 2023 | 09:42 PM
PixelDust's Avatar
So, it was bad injectors then?
Old Mar 25, 2023 | 05:28 PM
thanks for all the help and tips but no it wasnt bad injectors we hadnt noticed until we took down all the cables that one ground cable was kinda burnt
Old Mar 25, 2023 | 07:40 PM
PixelDust's Avatar
Awesome. Relief and frustration all at once. I know the feeling all too well.
rayos-x
Dec 10, 2022 03:07 PM
zantegeorge
Sep 6, 2021 03:24 PM
Syndave
Apr 29, 2020 06:30 PM
Davidgayrn
Dec 17, 2017 04:43 PM
robmcconnell
Nov 6, 2005 09:25 PM
