A Volvo R engine in a Mustang?????
Old Dec 5, 2008 | 03:40 PM
CM2RAS's Avatar
Default A Volvo R engine in a Mustang?????
I was tlaking to a guy that said he put a Volvo R engine in a 66 Ford Mustang! He said he made mount to turn it the right way and had a machine shop make a trans housing that worked. I think he was on drugs but has anyone ever heard of some one retrofitting a Volvo engine into another type car? Can you even buy the computer to make it run if it is not in a Volvo?
Old Dec 5, 2008 | 03:47 PM
draperj1's Avatar
Default RE: A Volvo R engine in a Mustang?????
actually i have heard of people putting 5.0 mustangs in 940's and 740's there is enough space
Old Dec 5, 2008 | 03:56 PM
CM2RAS's Avatar
Okay, but this guy was going the other way with a R engine into a Mustang. Is it possible?
Old Dec 5, 2008 | 04:35 PM
I have never seen that but would kind of like to. All you would have to do is use the Volvo harness in there after all the mountes were made.
Old Dec 5, 2008 | 04:38 PM
TIPSP's Avatar
Got Boost?
I have seena couple peoplemount the 20valve motors in their 242s. Itlooks pretty much the same as doing the V8 swap.
You would have to run a programmable engine management for those swaps.
Here is one: http://forums.turbobricks.com/showthread.php?t=142020
and another: http://forums.turbobricks.com/showthread.php?t=132921
Old Dec 8, 2008 | 09:17 PM
swiftjustice44's Avatar
Sure you can...my only question would be why? There are so many Ford motor options that would have been sooo much simpler. And, I too have heard rumors of V8's into 240's, 740's and 940's. Ross Converse has been making an SBF conversion kit for 15 years while Jags That Run generate a book with step by step instructions for using the much heavier 350 GM block. Here's a pic of the engine bay of my 90 740GL: It's a 347 stroker. Room? Much more in the 240 as the engine sits lower. My intake clears the hood by about an inch.
http://i243.photobucket.com/albums/f...T0001va4-1.jpg
And, for those that feel turboing an n/a rwd is cost prohibitive, this is my 89 245 w/ a 94 940T motor installed. I could just as easily turboed the original engine but it was completely worn out. I did the entire thing for a grand.
http://i243.photobucket.com/albums/f...tice44/cb3.jpg
http://i243.photobucket.com/albums/f...tice44/cb6.jpg
Old Dec 8, 2008 | 09:25 PM
Both look so SWEEEEEETTTTTT!!!!!
Here is a pic of my Buddies 740 Turbo with a custom made intake with a Mustang 65 or 70 MM throttle body.(sorry I forget which one he bought)
xDread92x
Nov 5, 2014 09:14 AM
BlueCracka
Jan 16, 2013 06:36 AM
BlueCracka
Jan 14, 2013 12:49 PM
JDvolvo33
May 16, 2012 09:53 PM
TopRedLine.com
Jan 9, 2009 06:44 AM
